Ir para o conteúdo principal
Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement
O que você precisa
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: passo 1, imagem 1 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: passo 1, imagem 2 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Power and Telephone Cords: passo 1, imagem 3 %32
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Screws to Base Plate: passo 2, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: passo 3, imagem 1 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: passo 3, imagem 2 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Remove Bottom Plate from Base: passo 3, imagem 3 %32
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
  4. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Screws: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the three 6mm screws from the phone and power jack cover plate.
    • Lift the phone and power jack cover plate away from the motherboard.
  5. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing the Motherboard Screw: passo 5, imagem 1 %32
    • Use a Philips #00 screwdriver to remove the single 6mm screw from the motherboard.
  6. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Glue Covering for Wire Connections: passo 6, imagem 1 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Removing Glue Covering for Wire Connections: passo 6, imagem 2 %32
    • Use the spudger tool to carefully scrape the glue off of the connection points of both the black and red wires.
  7. Polyconcept 900-MHz Retro Cordless Telephone Device Motherboard Replacement, Desoldering Wire Connections: passo 7, imagem 1 %32
    • Gently lift the motherboard away from the base plate and flip over.
    • Use the soldering station to desolder the wire connections.
    • For further instructions on using the soldering station click here.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 373
