Introdução
Being able to remove the keyboard will allow you to replace it or clean up the connections if the keyboard is not working properly.
O que você precisa
Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
