Ir para o conteúdo principal
Polaroid i835 LCD Replacement
O que você precisa
  1. Polaroid i835 LCD Replacement, LCD: passo 1, imagem 1 %32 Polaroid i835 LCD Replacement, LCD: passo 1, imagem 2 %32 Polaroid i835 LCD Replacement, LCD: passo 1, imagem 3 %32
    • remove the batteries, the memory card as well as the carrying strip (if so equipped).
    • Remove the 2 screws on the right hand side.
    • Remove the 2 screws on the left hand side.
  2. Polaroid i835 LCD Replacement: passo 2, imagem 1 %32 Polaroid i835 LCD Replacement: passo 2, imagem 2 %32 Polaroid i835 LCD Replacement: passo 2, imagem 3 %32
    • One more screw on the bottom, underneath the manufacturer's label.
    • Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick.
    • With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
  3. Polaroid i835 LCD Replacement: passo 3, imagem 1 %32 Polaroid i835 LCD Replacement: passo 3, imagem 2 %32
    • Lift the LCD out of the tray and move it to the right of the tray. The cable is still attached to the logic board via a latch.
    • With the plastic opening tool, or your fingernails, gently flip the latch to the left side. This will free the LCD cable. Remove the LCD and install your new one.
Conclusão
oldturkey03
Membro desde: 09/29/10
782.451 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 544 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 1,110
