Introdução
This process requires desoldering and the removal of many components. For more on information about soldering see here. However, replacing the screen for this device is not as difficult as screen replacement for many other devices.
O que você precisa
Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver and by turning the screws counterclockwise.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Wedge a plastic card beneath the battery unit.
Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
Desolder the following components from the motherboard.
Desolder from the motherboard the red wire that connects to the speaker unit.
Desolder from the motherboard the black wire that connects to the speaker unit.
Desolder from the motherboard the gray wire that runs along the edge of the device.
Ferramenta utilizada nesse passo:Tweezers$4.99
Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
Use a small opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
The motherboard and battery will now be detached from any ribbon cables connecting to the device.
Uma outra pessoa concluiu este guia.
