Ir para o conteúdo principal
Polaroid PMID701i 10 Battery Replacement
O que você precisa
  1. Polaroid PMID701i 10 Battery Replacement, Panel: passo 1, imagem 1 %32 Polaroid PMID701i 10 Battery Replacement, Panel: passo 1, imagem 2 %32
    • Turn off and unplug the device before starting replacement.
    • Flip the device so that the screen faces down, with the back facing up.
    • The back panel attaches to the device with four 4.0mm long screws, one at each corner, indicated by the red circles in the picture.
    • Unscrew the four screws with a PH000 screwdriver.
  2. Polaroid PMID701i 10 Battery Replacement: passo 2, imagem 1 %32 Polaroid PMID701i 10 Battery Replacement: passo 2, imagem 2 %32
    • Flip the device over so that the screen faces up, and the back faces down.
    • Separate the front panel using the Opening Tool on a corner to create an opening.
    • Removing the frame for the first time may take a significant amount of force.
    • Run the tool along the seams of the device to open up all the sides.
  3. Polaroid PMID701i 10 Battery Replacement: passo 3, imagem 1 %32
    • Removing the panel too quickly may damage the cable that attaches parts between the two panels.
    • Gently lift the top panel from the bottom panel.
  4. Polaroid PMID701i 10 Battery Replacement: passo 4, imagem 1 %32 Polaroid PMID701i 10 Battery Replacement: passo 4, imagem 2 %32
    • The flexible flat cables (FFC) attach to parts in the bottom panel with zero insertion force (ZIF) connectors.
    • Use the Opening tool to flip up the black retaining flap on the smaller connector.
    • Gently lift the cable, parallel to the panel, to detach it.
  5. Polaroid PMID701i 10 Battery Replacement: passo 5, imagem 1 %32 Polaroid PMID701i 10 Battery Replacement: passo 5, imagem 2 %32
    • Use the Opening tool to flip up the black retaining flap on the larger connector.
  6. Polaroid PMID701i 10 Battery Replacement, Battery: passo 6, imagem 1 %32
    • The battery is wrapped with tape. It is attached to the back plastic panel by glue.
    • The battery may bend if detached using a spudger or other small tool.
    • Grip the the battery by hand.
    • Due to the glue and shape of the battery it, it may take a significant amount of force to lift it.
    • Lift the battery, by hand, to remove it from the glue and panel.
  7. Polaroid PMID701i 10 Battery Replacement: passo 7, imagem 1 %32
    • The battery attaches to the motherboard with two wires, one red and one black.
    • Desolder the wires from the motherboard. For detailed information, refer to the Solder and Desolder guide.
  8. Polaroid PMID701i 10 Battery Replacement: passo 8, imagem 1 %32
    • Gently remove the battery, with the wires, from the panel and motherboard completely.
Conclusão
Uma outra pessoa concluiu este guia.
Amy Li
Membro desde: 01/31/17
627 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 3-4, Whitney Spring 2017 Membro de Baylor, Team 3-4, Whitney Spring 2017
BU-WHITNEY-S17S3G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 258
