Ir para o conteúdo principal
Polaroid P902 Motherboard Replacement
O que você precisa
    1. Polaroid P902 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
      • Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
      Pergunte ao FixBot
      Comentar
    2. Polaroid P902 Motherboard Replacement: passo 2, imagem 1 %32
      • Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
      Pergunte ao FixBot
      Comentar
    3. Polaroid P902 Motherboard Replacement: passo 3, imagem 1 %32 Polaroid P902 Motherboard Replacement: passo 3, imagem 2 %32
      • Using the PH00 screwdriver, unscrew the four 4.4 mm screws that are anchoring the circuit board down to the rest of the tablet.
      Pergunte ao FixBot
      Comentar
    4. Polaroid P902 Motherboard Replacement: passo 4, imagem 1 %32
      • Using your fingernail, gently lift up the connectors on the two tabs that are holding the ribbons in place to the circuit board.
      • Be careful when pulling out or reconnecting the ribbons, since if the ribbon or connectors break, they are hard to fix.
      Pergunte ao FixBot
      Comentar
    5. Polaroid P902 Motherboard Replacement: passo 5, imagem 1 %32 Polaroid P902 Motherboard Replacement: passo 5, imagem 2 %32 Polaroid P902 Motherboard Replacement: passo 5, imagem 3 %32
      • Using a soldering iron, desolder the points circled on the picture until the solder have liquefied enough to be able to remove the wires from the circuit board.
      Pergunte ao FixBot
      Comentar
    6. Polaroid P902 Motherboard Replacement: passo 6, imagem 1 %32
      • Gently lift the circuit board from the housing. You have now successfully removed the circuit board. Now, you can insert the new board to the tablet.
      Pergunte ao FixBot
      Comentar
Conclusão
Mina Tobeck
Membro desde: 03/26/18
133 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G2, Harley Spring 2018 Membro de IUPUI, Team S2-G2, Harley Spring 2018
IUPUI-HARLEY-S18S2G2
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 919
