Introdução
If you need to replace the lens this is guide will allow you to do so. You may need to replace the lens if it becomes scratched or cracked. For this replacement guide you will need to use the Shutter Switch replacement guide steps 1-4 as a precursor guide.
O que você precisa
Unscrew the four Phillips #0 5 mm screws on the base of the camera.
Remove the two pieces of the base.
1Comentário do guia
I followed this guide to a T, but it stops right before the replacement. I can even see the cracked lense in the last photo beneath the plastic lense you removed. How would one remove that internal lense and replace it?
