Introdução
You will need to replace the flash cover if the camera will not take clear pictures, has a cracked or scratched cover. You will need to use the Shutter Switch Replacement guide as a precursor guide.
O que você precisa
Unscrew the four 5mm screws on the base of the camera. Remove the two pieces of the base.
