Ir para o conteúdo principal
Polaroid One-Step 600 Battery Cartridge Replacement
    1. Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: passo 1, imagem 1 %32 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: passo 1, imagem 2 %32 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: passo 1, imagem 3 %32
      • Open the bottom compartment of the camera by sliding the lever towards the opening.
      Pergunte ao FixBot
      Comentar
    2. Polaroid One-Step 600 Battery Cartridge Replacement: passo 2, imagem 1 %32
      • Remove old battery/ film cartridge from camera.
      Pergunte ao FixBot
      Comentar
    3. Polaroid One-Step 600 Battery Cartridge Replacement: passo 3, imagem 1 %32
      • Follow the instructions that came with the new battery/ film cartridge to insert the new cartridge into the camera.
      • Close the battery compartment of the camera.
      • Note: The camera in this picture does not contain a battery.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
14 outras pessoas executaram este guia.
Doug Jimenez
Membro desde: 01/21/10
556 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 16-31, Maness Winter 2010 Membro de Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Membros
Autoria de 13 guias
15Comentários do guia
It worked but its expensive
Jessica diaz - Responder Compartilhar
I put new film in, it´s turning on, the flash is going off, but no film is coming out after the flash. What is the problem?
tristanmoeller2013 - Responder Compartilhar
nothing happened
new film installed
no sound
no flash
no action
eminickstone - Responder Compartilhar
I'm having the same issue
Marie - Responder Compartilhar
I'm having same issue.
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 50
Últimos 30 dias: 268
Ao todo: 159,171
