Ir para o conteúdo principal
Polaroid Cube Battery Replacement
O que você precisa
  1. Polaroid Cube Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
    Pergunte ao FixBot
    Comentar
  2. Polaroid Cube Battery Replacement: passo 2, imagem 1 %32
    • Use the Plastic Opening tool to pry off and remove the front cover.
    Pergunte ao FixBot
    Comentar
  3. Polaroid Cube Battery Replacement: passo 3, imagem 1 %32
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
    Pergunte ao FixBot
    Comentar
  4. Polaroid Cube Battery Replacement: passo 4, imagem 1 %32 Polaroid Cube Battery Replacement: passo 4, imagem 2 %32
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
    Pergunte ao FixBot
    Comentar
  5. Polaroid Cube Battery Replacement: passo 5, imagem 1 %32
    • Remove shell from top and bottom of camera.
    Pergunte ao FixBot
    Comentar
  6. Polaroid Cube Battery Replacement: passo 6, imagem 1 %32
    • Remove the rubber seal wrapped around the camera.
    Pergunte ao FixBot
    Comentar
  7. Polaroid Cube Battery Replacement: passo 7, imagem 1 %32 Polaroid Cube Battery Replacement: passo 7, imagem 2 %32
    • Remove the tape wrapped around the battery.
    Pergunte ao FixBot
    Comentar
  8. Polaroid Cube Battery Replacement: passo 8, imagem 1 %32 Polaroid Cube Battery Replacement: passo 8, imagem 2 %32 Polaroid Cube Battery Replacement: passo 8, imagem 3 %32
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
    Pergunte ao FixBot
    Comentar
  9. Polaroid Cube Battery Replacement: passo 9, imagem 1 %32 Polaroid Cube Battery Replacement: passo 9, imagem 2 %32
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
    Pergunte ao FixBot
    Comentar
  10. Polaroid Cube Battery Replacement: passo 10, imagem 1 %32
    • Gently remove the battery pin connector from the circuit board.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Equipe
IUPUI, Team 3-2, Harley Fall 2016 Membro de IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Membros
Autoria de 3 guias
13Comentários do guia
Any idea where to find the replacement batteries?
hooverhogg - Responder Compartilhar
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
seyhangul - Responder Compartilhar
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
David F O'Connor - Responder Compartilhar
Was anyone able to to find the replacement batteries for the Cube?
yzorger - Responder Compartilhar
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Timothy Davenport - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 70
Ao todo: 10,885
