Ir para o conteúdo principal
Polaroid Automatic 100 Bottom Frame Spring Replacement
O que você precisa
  1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, imagem 1 %32 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, imagem 2 %32 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: passo 1, imagem 3 %32
    • Fully extend the bellows to prevent collapse using the #1 tab.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
    Pergunte ao FixBot
    Comentar
  2. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 2, imagem 1 %32
    • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
    Pergunte ao FixBot
    Comentar
  3. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 3, imagem 1 %32
    • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, imagem 1 %32 Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, imagem 2 %32 Polaroid Automatic 100 Bottom Frame Spring Replacement: passo 4, imagem 3 %32
    • Remove the spring from the shutter mount.
    • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
    • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
    Pergunte ao FixBot
    Comentar
Conclusão
Katie Miller
Membro desde: 04/14/15
680 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 4-3, Maness Spring 2015 Membro de Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Membros
Autoria de 6 guias
2Comentários do guia
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Responder Compartilhar
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 1,543
