Ir para o conteúdo principal
Polar V800 Watch Band Replacement
O que você precisa
  1. Polar V800 Watch Band Replacement, Watch Band: passo 1, imagem 1 %32 Polar V800 Watch Band Replacement, Watch Band: passo 1, imagem 2 %32 Polar V800 Watch Band Replacement, Watch Band: passo 1, imagem 3 %32
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Watch Band Replacement: passo 2, imagem 1 %32 Polar V800 Watch Band Replacement: passo 2, imagem 2 %32 Polar V800 Watch Band Replacement: passo 2, imagem 3 %32
    • To remove the watch band, pull each end of the watch band away from the watch frame.
Conclusão
Uma outra pessoa concluiu este guia.
Jarod Lyles
Membro desde: 04/18/18
833 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S17-G6, Livingston Spring 2018 Membro de Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Membros
Autoria de 8 guias
8 comentários
There is no way for me to remove the clips, they are stuck and don’t move, any ideas on how to loosen them?
Gustavo Fette - Responder
I have the same issue. Any idea?
smichaud777 - Responder
Same issue here, they wont budge. You guys above found any solution?
Kris - Responder
No, I guess I won’t Be buying Polar stuff no more… can’t believe it…
Gustavo Fette -
The Pins move out! Like described above, there is one side with a larger head of the pin. This is the side where the pin comes out. The smaller side is where you push. Due to water and sweat, there is some kind off corrosion or buildup around the pin.This is why it does not come out easy. Important is to use right size of the tool. Lubrication with WD40 silicone oil helps.
Michael_B - Responder
Well done - nice and easy. I thought I might have to unscrew the screws but no, the pin just pushes out. Clearly explained. Thank you.
Alan Kirk - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 7,669
