Ir para o conteúdo principal
Polar M400 Watch Battery Replacement
O que você precisa
  1. Polar M400 Watch Battery Replacement, Wrist Strap: passo 1, imagem 1 %32
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
    Pergunte ao FixBot
    Comentar
  2. Polar M400 Watch Battery Replacement: passo 2, imagem 1 %32 Polar M400 Watch Battery Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
    Pergunte ao FixBot
    Comentar
  3. Polar M400 Watch Battery Replacement: passo 3, imagem 1 %32
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
    Pergunte ao FixBot
    Comentar
  4. Polar M400 Watch Battery Replacement, Battery: passo 4, imagem 1 %32
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
    Pergunte ao FixBot
    Comentar
  5. Polar M400 Watch Battery Replacement: passo 5, imagem 1 %32 Polar M400 Watch Battery Replacement: passo 5, imagem 2 %32
    • Gently remove the backing from the watch.
    Pergunte ao FixBot
    Comentar
  6. Polar M400 Watch Battery Replacement: passo 6, imagem 1 %32 Polar M400 Watch Battery Replacement: passo 6, imagem 2 %32
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
    Pergunte ao FixBot
    Comentar
Conclusão
16 outras pessoas executaram este guia.
25Comentários do guia
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Responder Compartilhar
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman - Responder Compartilhar
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Responder Compartilhar
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Responder Compartilhar
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 32
Últimos 30 dias: 130
Ao todo: 36,324
