Ir para o conteúdo principal
Pokewalker Battery Replacement
O que você precisa
    1. Pokewalker Battery Replacement, Battery: passo 1, imagem 1 %32
      • Locate the Screw on the Back of the Pokewalker.
      Pergunte ao FixBot
      Comentar
    2. Pokewalker Battery Replacement: passo 2, imagem 1 %32
      • Remove the Screw with a Phillips #0 Screwdriver
      • The screw is attached to the rear case with washers. don't worry about losing it.
      Pergunte ao FixBot
      Comentar
    3. Pokewalker Battery Replacement: passo 3, imagem 1 %32
      • Remove the Rear Cover from the Device
      Pergunte ao FixBot
      Comentar
    4. Pokewalker Battery Replacement: passo 4, imagem 1 %32
      • Use the flat end of a Spudger to Remove the Battery
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
Winni Stuart
Membro desde: 04/13/14
447 Reputação
Autoria de 2 guias
3Comentários do guia
The battery must be placed positive side facing up if I am correct.
I just dug my pokewalker out of my closet. Been years since it has been used. Putting in an effort to get it running again.
Thanks for the tutorial.
Jake Allen - Responder Compartilhar
I just got my Pokéwalker up and running again as well. Nintendo's stuff is always so well made.
signature - Responder Compartilhar
My pokewalker had an accidental trip inside the washing machine yesterday, all fine except needed a fresh battery today! Working well again. Bless you ifixit and nintendo.
Old Trainer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 63
Últimos 30 dias: 312
Ao todo: 37,746
