Introdução
Use this guide to remove the back cover on your Xiaomi Pocophone F1.
O que você precisa
Before you begin, switch off your phone.
Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the left edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Remove the two 2.7 mm-long Torx T3 screws from the bottom edge of your phone.
Insert an opening tool between the screen and the back cover at the bottom edge of the screen.
Slide the opening tool to the bottom right corner to release the plastic clips holding the back cover in place.
Slide the opening tool around the bottom right corner.
Slide the opening tool along the right edge of the Pocophone F1 to release the plastic clips.
Use the flat end of a spudger to pry up and disconnect the fingerprint flex connector.
Remove the back cover.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
16 outras pessoas executaram este guia.
2Comentários do guia
Thank for the help
Me salvo de tirar mi celular 10/10
