Ir para o conteúdo principal
PlayStation Vita Left Joystick Replacement
O que você precisa
  1. PlayStation Vita Left Joystick Replacement, Case Separation: passo 1, imagem 1 %32 PlayStation Vita Left Joystick Replacement, Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Left Joystick Replacement: passo 2, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 2, imagem 2 %32 PlayStation Vita Left Joystick Replacement: passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Left Joystick Replacement: passo 3, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Left Joystick Replacement: passo 4, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 4, imagem 2 %32 PlayStation Vita Left Joystick Replacement: passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Left Joystick Replacement: passo 5, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Responder
  6. PlayStation Vita Left Joystick Replacement: passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Left Joystick Replacement: passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Responder
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Responder
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Responder
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Responder
    broke the white part
    Benaya Miller - Responder
  8. PlayStation Vita Left Joystick Replacement: passo 8, imagem 1 %32
    • Separate the front and rear cases.
  9. PlayStation Vita Left Joystick Replacement, Left Shoulder Button: passo 9, imagem 1 %32 PlayStation Vita Left Joystick Replacement, Left Shoulder Button: passo 9, imagem 2 %32 PlayStation Vita Left Joystick Replacement, Left Shoulder Button: passo 9, imagem 3 %32
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Left Joystick Replacement: passo 10, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 10, imagem 2 %32
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Left Joystick Replacement: passo 11, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 11, imagem 2 %32 PlayStation Vita Left Joystick Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
    broke the small black tab, what happens if I just go without it??
    Nicolas Porfirio - Responder
  12. PlayStation Vita Left Joystick Replacement: passo 12, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 12, imagem 2 %32
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
    This step is unneccesary.
    Alexander Mayatsky - Responder
  13. PlayStation Vita Left Joystick Replacement, Left Button Board: passo 13, imagem 1 %32 PlayStation Vita Left Joystick Replacement, Left Button Board: passo 13, imagem 2 %32
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
    Este paso NO es necesario si tu PSVita no tiene lector de tarjeta SIM. Ve directamente al paso 15.
    Parappa The Rapper - Responder
  14. PlayStation Vita Left Joystick Replacement: passo 14, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 14, imagem 2 %32 PlayStation Vita Left Joystick Replacement: passo 14, imagem 3 %32
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
    This board is not present in the Wifi only version, only the 3G/Wifi version.
    dodo - Responder
  15. PlayStation Vita Left Joystick Replacement: passo 15, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 15, imagem 2 %32
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  16. PlayStation Vita Left Joystick Replacement: passo 16, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 16, imagem 2 %32
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  17. PlayStation Vita Left Joystick Replacement: passo 17, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 17, imagem 2 %32
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
    This connector isn't present in the Wifi only version, just the 3G/Wifi version.
    dodo - Responder
  18. PlayStation Vita Left Joystick Replacement: passo 18, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 18, imagem 2 %32 PlayStation Vita Left Joystick Replacement: passo 18, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
    What is the loose looking cable in this photo?
    Dallon Verhaeghe - Responder
  19. PlayStation Vita Left Joystick Replacement: passo 19, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 19, imagem 2 %32 PlayStation Vita Left Joystick Replacement: passo 19, imagem 3 %32
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
  20. PlayStation Vita Left Joystick Replacement, Left Joystick: passo 20, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the two blue, 5.0mm screws attaching the left joystick to the back case.
  21. PlayStation Vita Left Joystick Replacement: passo 21, imagem 1 %32 PlayStation Vita Left Joystick Replacement: passo 21, imagem 2 %32 PlayStation Vita Left Joystick Replacement: passo 21, imagem 3 %32
    • Using a spudger, pry up and remove the left joystick.
Conclusão
50 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.769 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.560 guias
10 comentários
Is it possible to purchase new ps vita analog sticks to replace beaten up ones with?
kay - Responder
Yes. I found them on dealextreme.com, but then saw that shipping could take awhile and double the price. I found a better deal on eBay-- $22 including shipping for a new analog stick.
dodo - Responder
I Live in Kendall,Miami,Does anyone could tell me if there is a place where can I fix my PSVita (The left stick dosent work) Thanks
jamalonso94 - Responder
I have followed these instructions
I have succeeded to replace the joystick but the psvita dont want to turn on and refuse to charge
before the fix the battery was charged to 80%
I have checked all the cables and everything is good
When I push on the power button, the PS light go to orange and stop when I relax the power button
Could you help me please?
mbouchet42 - Responder
Turn on the system let it charge then put it back to sleep
travishenry318 - Responder
is there anywhere i can go to pay someone to do this for me?
Nathan Baker - Responder
is there any safer way
tonya.morse35 - Responder
can i do most of these without a spudge?
karlo.maico - Responder
Is there any way to disassemble, clean and reassebmle the analog module? My Vita has issues with the analog sticks and all the replacement analog sticks I’ve bought so far also have issues. Some people have suggested taking out the flex cable and cleaning the contact points, but I’m not sure how to do that.
vladmoraru97 - Responder
Perfecto... ni diez minutos con esta gran guia... gracias.
Pequeño Francisco - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 22
Últimos 7 dias: 96
Últimos 30 dias: 381
Ao todo: 85,758
