Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
Pull the power supply cable straight up and out of its socket on the power supply to disconnect it.
Remove the two 14 mm-long Phillips #1 screws securing the power supply to the bottom case.
Lift the outer edge of the power supply slightly, then rotate the whole power supply away from the small clip on its inner edge to remove the power supply.
24 outras pessoas executaram este guia.
4 comentários
im done removing the power supply so whats next???btw i accidentally plugged my ps1 110v to 220v how to fix that issue???
Before anything unplug your PlayStation and try the power button couple a times to turn on the PlayStation.
Just check the fuse with a multimeter. It is a cylindrical tube with metal on it’s two corners. The easy way is to check continuity with a mutimeter which is a symbol with a speaker on it. Touch red and black probes and you will hear a beep. Connect the two ends of the fuse and if it beeps then fuse is ok. You can even check it while fuse is on the board. If ok and PlayStation is not working then there is a problem somewhere else on the power board, mostly…
Good Luck!!
gUru0026 -
