Ir para o conteúdo principal
PlayStation Move USB Port Replacement
O que você precisa
  1. PlayStation Move USB Port Replacement, Case: passo 1, imagem 1 %32 PlayStation Move USB Port Replacement, Case: passo 1, imagem 2 %32
    • Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
  2. PlayStation Move USB Port Replacement: passo 2, imagem 1 %32 PlayStation Move USB Port Replacement: passo 2, imagem 2 %32 PlayStation Move USB Port Replacement: passo 2, imagem 3 %32
    • Pinch the sides of the back panel to remove it and set it aside.
  3. PlayStation Move USB Port Replacement: passo 3, imagem 1 %32 PlayStation Move USB Port Replacement: passo 3, imagem 2 %32
    • Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
  4. PlayStation Move USB Port Replacement: passo 4, imagem 1 %32 PlayStation Move USB Port Replacement: passo 4, imagem 2 %32
    • Push the Lithium Ion battery from its slot to remove it.
    • Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
  5. PlayStation Move USB Port Replacement: passo 5, imagem 1 %32
    • Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
  6. PlayStation Move USB Port Replacement: passo 6, imagem 1 %32 PlayStation Move USB Port Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, carefully pry the rumble motor free.
  7. PlayStation Move USB Port Replacement: passo 7, imagem 1 %32
    • Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
  8. PlayStation Move USB Port Replacement: passo 8, imagem 1 %32 PlayStation Move USB Port Replacement: passo 8, imagem 2 %32 PlayStation Move USB Port Replacement: passo 8, imagem 3 %32
    • Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
  9. PlayStation Move USB Port Replacement: passo 9, imagem 1 %32 PlayStation Move USB Port Replacement: passo 9, imagem 2 %32
    • Using your fingers, carefully pry the square green piece beneath the battery slot free.
    • It is attached via white ribbons which need to be kept intact.
  10. PlayStation Move USB Port Replacement: passo 10, imagem 1 %32 PlayStation Move USB Port Replacement: passo 10, imagem 2 %32 PlayStation Move USB Port Replacement: passo 10, imagem 3 %32
    • Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
    • Lift the rectangular piece from its slot to free it.
  11. PlayStation Move USB Port Replacement: passo 11, imagem 1 %32 PlayStation Move USB Port Replacement: passo 11, imagem 2 %32 PlayStation Move USB Port Replacement: passo 11, imagem 3 %32
    • Carefully lift the entire circuit board from the black plastic encasing it.
    • Take extra care not to damage any of the wired components.
  12. PlayStation Move USB Port Replacement, USB Port: passo 12, imagem 1 %32
    • At the end of the circuit board, you should see a small silver connector port (this is the USB).
    • Using a soldering iron, carefully desolder the port from the board. For help with desoldering, please reference this guide: How To Solder and Desolder Connections
    • In order to reinstall the new USB port, you must solder the new one to the board.
Conclusão
Sarah Shand
Membro desde: 02/20/17
1.885 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S3-G1, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
Membros da 3
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 38
Duração total: 2,544
