Introdução
Follow this guide to remove and replace the power supply on a PlayStation 5.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
O que você precisa
If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
Use a pair of tweezers or your fingernail to remove the cap from the cubby.
Use your finger to press the cap into the screw hole.
If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
Lift the stand straight up to remove it.
Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
Lift up the corner of the faceplate to unclip it from the case.
Insert the flat end of a spudger underneath the grille and into the gap above the fan.
Lift up with the spudger to pry the grille away from the case.
Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
Two 23.3 mm-long screws
One 11.4 mm-long screw
One 31 mm-long screw
Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
Use the spudger to peel up the wire cover until you can grip it with your fingers.
Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
Use a T8 Torx driver to remove the eleven screws securing the case:
Six 18.6 mm-long screws
Two 43.2 mm-long screws
One 7.3 mm-long screw
Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
Lift the wire's connector straight up to disconnect it from the motherboard.
Repeat for the black Wi-Fi antenna wire.
Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
Remove the antenna wires from underneath the sticker.
Press the white sticker back down onto the top shield plate so it can be reused.
Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
Forty-one 7.3 mm-long screws
One 43.2 mm-long screw
Lift the top shield plate off of the motherboard to remove it.
Use your finger to depress the metal locking tab on the USB board cable's board connector.
With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
Use a Torx T8 driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
Lift the front edge of the case off of the motherboard and heat sink assembly.
With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
Remove the case.
Use a finger to hold the rear shield plate down against the work surface.
Grip the power supply and lift it straight up to disconnect it from the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
28 outras pessoas executaram este guia.
15 comentários
So I started with a dead PS5. I had another power supply laying about but from a different revision. I replaced the power supply with said other power supply that works. When I put it back together still no power. Does each revision used a different power supply or would it be the same?
i’m having the same problem, did you ever get it to work?
abrey -
