Introdução
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Follow this guide to remove the optical drive on a PlayStation 5.
The optical drive is paired to the motherboard, so a replacement optical drive won’t read discs.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
O que você precisa
If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
Lift the stand straight up to remove it.
Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
Lift up the corner of the faceplate to unclip it from the case.
Insert the flat end of a spudger underneath the grille and into the gap above the fan.
Lift up with the spudger to pry the grille away from the case.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
Two 23.3 mm-long screws
One 11.4 mm-long screw
One 31 mm-long screw
Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
Use the spudger to peel up the wire cover until you can grip it with your fingers.
Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
Use a T8 Torx driver to remove the eleven screws securing the case:
Six 18.6 mm-long screws
Two 43.2 mm-long screws
One 7.3 mm-long screw
Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
