Ir para o conteúdo principal
PlayStation 5 Faceplates Replacement
O que você precisa
  1. PlayStation 5 Faceplates Replacement, Remove the stand screw: passo 1, imagem 1 %32
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Faceplates Replacement, Remove the vertical stand: passo 2, imagem 1 %32 PlayStation 5 Faceplates Replacement, Remove the vertical stand: passo 2, imagem 2 %32
    • Lift straight up to remove the stand.
  3. PlayStation 5 Faceplates Replacement, Store the stand screw: passo 3, imagem 1 %32 PlayStation 5 Faceplates Replacement, Store the stand screw: passo 3, imagem 2 %32
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Faceplates Replacement, Cap the screw hole: passo 4, imagem 1 %32 PlayStation 5 Faceplates Replacement, Cap the screw hole: passo 4, imagem 2 %32 PlayStation 5 Faceplates Replacement, Cap the screw hole: passo 4, imagem 3 %32
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Faceplates Replacement, Close the cubby: passo 5, imagem 1 %32 PlayStation 5 Faceplates Replacement, Close the cubby: passo 5, imagem 2 %32 PlayStation 5 Faceplates Replacement, Close the cubby: passo 5, imagem 3 %32
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Faceplates Replacement, Remove the horizontal stand: passo 6, imagem 1 %32 PlayStation 5 Faceplates Replacement, Remove the horizontal stand: passo 6, imagem 2 %32
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Faceplates Replacement, Remove the left faceplate: passo 7, imagem 1 %32 PlayStation 5 Faceplates Replacement, Remove the left faceplate: passo 7, imagem 2 %32 PlayStation 5 Faceplates Replacement, Remove the left faceplate: passo 7, imagem 3 %32
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  8. PlayStation 5 Faceplates Replacement: passo 8, imagem 1 %32 PlayStation 5 Faceplates Replacement: passo 8, imagem 2 %32
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the left faceplate.
  9. PlayStation 5 Faceplates Replacement, Remove the right faceplate: passo 9, imagem 1 %32 PlayStation 5 Faceplates Replacement, Remove the right faceplate: passo 9, imagem 2 %32 PlayStation 5 Faceplates Replacement, Remove the right faceplate: passo 9, imagem 3 %32
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  10. PlayStation 5 Faceplates Replacement: passo 10, imagem 1 %32 PlayStation 5 Faceplates Replacement: passo 10, imagem 2 %32
    • Remove the right faceplate.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
14 outras pessoas executaram este guia.
Clay Kim
Membro desde: 02/16/21
9.716 Reputação
Autoria de 21 guias
Um comentário
Hello, thanks for the updates
hadi rp - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 135
Últimos 30 dias: 641
Duração total: 14,111
