Ir para o conteúdo principal
PlayStation 4 Pro Hard Drive Replacement
O que você precisa
  1. PlayStation 4 Pro Hard Drive Replacement, Hard Drive Cover: passo 1, imagem 1 %32
    • Start by flipping the PS4 Pro over its top.
    • Remove the plastic panel covering the drive bay, using the tab next to the Ethernet port.
    Pergunte ao FixBot
    Comentar
  2. PlayStation 4 Pro Hard Drive Replacement, Hard Drive Caddy: passo 2, imagem 1 %32
    • Remove the Phillips #0 screw securing the hard drive caddy to the chassis.
    Pergunte ao FixBot
    Comentar
  3. PlayStation 4 Pro Hard Drive Replacement, Hard drive: passo 3, imagem 1 %32
    • Slide the hard drive caddy out.
    • Remove the four Phillips #0 screws securing the hard drive to the caddy.
    Pergunte ao FixBot
    Comentar
Conclusão
80 outras pessoas executaram este guia.
Ronnie
Membro desde: 10/22/12
3.851 Reputação
Autoria de 5 guias
9Comentários do guia
Bought a screwdriver from amazon and didn’t work. Bought the screwdriver linked on this guide and it worked flawlessly. Thanks
javz - Responder Compartilhar
Does this work the same for PS4 slim?
Matthew - Responder Compartilhar
i want to change the hard drive in my ps4 to a 5tb (2.5”) but does this transfer trophies if i don’t use internet (PSN) to save them?
ANY HELP!!!!
Lewis Jenkins - Responder Compartilhar
hope you already solve this issue, but if not, there’s a backup option to save or backup them to a USB drive (thumb drive)
Rodrigo Vasquez - Responder Compartilhar
Możesz zrobić kopię zapasową na przenośnym dysku USB . Dane można przenosić z jednej konsoli na drugą bez problemu.
Zryf - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 22
Últimos 7 dias: 124
Últimos 30 dias: 563
Ao todo: 53,176
