Introdução
Use this guide to completely replace your motherboard. Before reattaching the heat sink, be sure to apply a new layer of thermal paste.
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
Pull the AC-In cables upward to remove the AC inlet from the lower case.
Disconnect the DC-In and Blu-ray power cables from the motherboard.
72 outras pessoas concluíram este guia.
9 comentários
do not force the fan cables out , my grey cable broke of and my power supply cable attached to the motherboard, make sure you take the whole white cable rapped with inselation tape to mae sure the chip doesnt brake off . good luck with it
ps rather let a trained professional do it .
my ps3 not work ,i toke my ps3 to a ingner he cannt fix it he tell me there is no electrsety in mother board even that replesment the power supply
can any one help me how can i fix it, and how much the motherboard cost ?
