Introdução
Use this guide to replace your heat sink. It is essential to apply a new layer of thermal paste during reassembly.
O que você precisa
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
Pull the AC-In cables upward to remove the AC inlet from the lower case.
Disconnect the DC-In and Blu-ray power cables from the motherboard.
38 outras pessoas executaram este guia.
7 comentários
Thanks for this guide
Hi, is the heatsink that makes contact with the cpu die aluminium? I think I might have repasted it with liquid metal… Thanks!
