Ir para o conteúdo principal
PlayStation 3 Hard Drive Replacement
O que você precisa
  1. PlayStation 3 Hard Drive Replacement, Hard Drive Backup: passo 1, imagem 1 %32 PlayStation 3 Hard Drive Replacement, Hard Drive Backup: passo 1, imagem 2 %32
    • If you need to backup the data on your current hard drive, follow the instructions in this step. Otherwise, continue to the next step.
    • On a Windows/OS X/Linux machine, format an external USB hard drive (with enough space available to backup your current hard content) into the FAT32 file system.
    • Make sure it's formatted FAT32. The Playstation 3 backup utility will not recognize any other file system.
    • Connect your formatted hard drive to the Playstation 3 through a USB port and power the console up.
    • Navigate the XMB to the 'Settings' menu and select 'System Settings'
    • Select the 'Backup Utility' function to create a backup of your data - this can take up to 2 hours if you have a lot of data on the PS3.
    Pergunte ao FixBot
    Comentar
  2. PlayStation 3 Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32 PlayStation 3 Hard Drive Replacement, Hard Drive: passo 2, imagem 2 %32
    • Use the flat end of a spudger to pry the hard drive door away from the lower case.
    • Remove the hard drive door from the PS3.
    Pergunte ao FixBot
    Comentar
  3. PlayStation 3 Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
    Pergunte ao FixBot
    Comentar
  4. PlayStation 3 Hard Drive Replacement: passo 4, imagem 1 %32 PlayStation 3 Hard Drive Replacement: passo 4, imagem 2 %32 PlayStation 3 Hard Drive Replacement: passo 4, imagem 3 %32
    • Grab the hard drive pull tab and pull the hard drive toward the front face of the PS3.
    • Pull the hard drive assembly out of the PS3.
    Pergunte ao FixBot
    Comentar
  5. PlayStation 3 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 PlayStation 3 Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    Screw Extracting Pliers
    $23.95
    • Remove the four 4.3 mm Phillips screws securing the hard drive cage to the hard drive.
    • These 4 screws can sometimes be very difficult to remove. If you strip the heads our Screw Extracting Pliers remove the damaged screws nicely.
    Pergunte ao FixBot
    Comentar
  6. PlayStation 3 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the hard drive from its steel cage.
    • If you're installing a new hard drive into your PS3, use this guide to restore the data you backed up.
    Pergunte ao FixBot
    Comentar
Conclusão
165 outras pessoas executaram este guia.
19Comentários do guia
Hi there!
Thank you for this (and all the other) guide!
My Hard Drive Slot looks a little bit different.
You have to spudge away the door from the left side and after removing the Blue Screw you can easily pull out the harddrive and you don't have to slide the tray to the side and out afterwards.
Maybe worth a note that there are several versions around..
Jay Ho - Responder Compartilhar
Nice explenatory guide!
Dirk Ronsmans - Responder Compartilhar
My playstation3 fell over" lost all my icons on screen. I took it in to see what's wrong, they say I need to replace hard drive. Were can I buy a hard drive and how much does it cost? Can I do it myself? Please give me some answers or tips
alexhuman49 - Responder Compartilhar
if you can’t figure that out you should stop gaming…
Azhrei2000 - Responder Compartilhar
You can find a new hard drive on Amazon. Data's gone, though.
TheTank20 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 36
Últimos 7 dias: 307
Últimos 30 dias: 1,286
Ao todo: 260,632
