Introdução
This guide will walk you through step-by-step on how to properly remove and install the IR sensor in the PlayStation 2 Slimline.
O que você precisa
Passo 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Cuidado: as etapas de 1 a 7 são provenientes de um guia marcado como em andamento.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
4 outras pessoas executaram este guia.
