Ir para o conteúdo principal
PlayStation 2 Fan Replacement
O que você precisa
  1. PlayStation 2 Fan Replacement, Top Cover: passo 1, imagem 1 %32 PlayStation 2 Fan Replacement, Top Cover: passo 1, imagem 2 %32 PlayStation 2 Fan Replacement, Top Cover: passo 1, imagem 3 %32
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    Pergunte ao FixBot
    Comentar
  2. PlayStation 2 Fan Replacement: passo 2, imagem 1 %32
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
    Pergunte ao FixBot
    Comentar
  3. PlayStation 2 Fan Replacement: passo 3, imagem 1 %32
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
    Pergunte ao FixBot
    Comentar
  4. PlayStation 2 Fan Replacement: passo 4, imagem 1 %32 PlayStation 2 Fan Replacement: passo 4, imagem 2 %32
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    Pergunte ao FixBot
    Comentar
  5. PlayStation 2 Fan Replacement, Power Board: passo 5, imagem 1 %32 PlayStation 2 Fan Replacement, Power Board: passo 5, imagem 2 %32
    • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
    • Lift and remove the optical disc drive straight up out of the bottom case.
    Pergunte ao FixBot
    Comentar
  6. PlayStation 2 Fan Replacement: passo 6, imagem 1 %32 PlayStation 2 Fan Replacement: passo 6, imagem 2 %32
    • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
    Pergunte ao FixBot
    Comentar
  7. PlayStation 2 Fan Replacement: passo 7, imagem 1 %32 PlayStation 2 Fan Replacement: passo 7, imagem 2 %32
    • Gently lift the controller port board out of its recess within the bottom case.
    • Do not completely remove the controller port board. It is still attached via a ribbon cable.
    • Pull the controller port ribbon cable straight away from its socket on the controller port board.
    • Remove the controller port board out of the bottom case.
    Pergunte ao FixBot
    Comentar
  8. PlayStation 2 Fan Replacement: passo 8, imagem 1 %32
    • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
    Pergunte ao FixBot
    Comentar
  9. PlayStation 2 Fan Replacement: passo 9, imagem 1 %32
    • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
    • Pry and remove the expansion bay cover away from its posts on the bottom case.
    Pergunte ao FixBot
    Comentar
  10. PlayStation 2 Fan Replacement: passo 10, imagem 1 %32
    • Lift the motherboard assembly from its front edge and remove it from the lower case.
    Pergunte ao FixBot
    Comentar
  11. PlayStation 2 Fan Replacement: passo 11, imagem 1 %32
    • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
    • Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
    Pergunte ao FixBot
    Comentar
  12. PlayStation 2 Fan Replacement: passo 12, imagem 1 %32
    • Lift the expansion bay cage up off the motherboard assembly.
    Pergunte ao FixBot
    Comentar
  13. PlayStation 2 Fan Replacement: passo 13, imagem 1 %32 PlayStation 2 Fan Replacement: passo 13, imagem 2 %32
    • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
    • Carefully lift the power board. You should now see the power board connector attached to the power board.
    • Pull the power board connector straight to lift it out of its socket on the power board.
    Pergunte ao FixBot
    Comentar
  14. PlayStation 2 Fan Replacement, Fan: passo 14, imagem 1 %32
    • The transparent piece of plastic located underneath the power supply recess in the motherboard assembly is the heat shield.
    • Remove the heat shield from the motherboard assembly.
    • Dislodging the heat shield can be a bit stubborn, so it may take a little finessing to get it free.
    Pergunte ao FixBot
    Comentar
  15. PlayStation 2 Fan Replacement: passo 15, imagem 1 %32 PlayStation 2 Fan Replacement: passo 15, imagem 2 %32 PlayStation 2 Fan Replacement: passo 15, imagem 3 %32
    • We can now remove the fan and main power switch assembly.
    • Remove the small white piece of tape (highlighted in red) that holds the fan cable connected to the fan.
    • Pull the fan cable straight up from its socket on the motherboard.
    • The fan and power switch are now free from the rest of the PlayStation 2.
    • Remove the fan and power switch assembly by pulling it out the bottom case.
    Pergunte ao FixBot
    Comentar
  16. PlayStation 2 Fan Replacement: passo 16, imagem 1 %32
    • Remove the fan from the power switch assembly.
    • The fan simply slides out of the top along its track.
    Pergunte ao FixBot
    Comentar
  17. PlayStation 2 Fan Replacement: passo 17, imagem 1 %32
    • Remove the power switch from its recess within the fan/power switch holder.
    • The power switch simply slides out just like the fan.
    Pergunte ao FixBot
    Comentar
Conclusão
You’ve successfully replaced the PlayStation 2 fan! Plug the console back in and power it on to ensure the fan is spinning normally. To reassemble your device, follow these instructions in reverse order.
42 outras pessoas executaram este guia.
Documentos anexados
jwyoung
Membro desde: 11/04/09
3.199 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 19-1, Maness Fall 2009 Membro de Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Membros
Autoria de 35 guias
11Comentários do guia
what about on fixing when the unit doesn't turn back on? Replaced the ribbon cable after blowing out the dust, reassemble the unit and it didn't turn back on no green or red light's.
themidnightdj - Responder Compartilhar
You should check to c if the side with the blue is on the top @ the silver on the bottom
Trudy Green - Responder Compartilhar
What do I do if the fan connector to motherboard has a broken leg? Can I rewire the connector to other points to solder to the board?
RJ Weber - Responder Compartilhar
What about the slim model? Is there a guide for that?
the stronk green bean - Responder Compartilhar
I have a question about this I just want to clean off the fan not replace it how do I do
Miranda Decker - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 124
Últimos 30 dias: 572
Ao todo: 118,529
