Introdução
The earpiece unit on the Plantronics Voyager Legend consists of a soft-plastic earpiece, a plastic housing, a wire assembly, and the actual speaker unit. The assembly is held together by glue and snaps making disassembly difficult.
O que você precisa
Remove the soft, plastic earpiece.
Depress the soft, plastic earpiece. While depressed, rotate the earpiece counterclockwise ninety degrees.
List the soft, plastic earpiece out of its position.
7 outras pessoas executaram este guia.
Um comentário
Thank you for the Guide.
One further Question is open for me: How do you replace the broken rubber near the earpiece?
