Ir para o conteúdo principal
Plantronics CS50 Headset Motherboard Replacement
O que você precisa
  1. Plantronics CS50 Headset Motherboard Replacement, Battery: passo 1, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement, Battery: passo 1, imagem 2 %32 Plantronics CS50 Headset Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Motherboard Replacement: passo 2, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement: passo 2, imagem 2 %32 Plantronics CS50 Headset Motherboard Replacement: passo 2, imagem 3 %32
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
  3. Plantronics CS50 Headset Motherboard Replacement, Microphone: passo 3, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement, Microphone: passo 3, imagem 2 %32
    • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
    • Apply additional heat at the tip of the microphone.
  4. Plantronics CS50 Headset Motherboard Replacement: passo 4, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement: passo 4, imagem 2 %32
    • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
    • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
  5. Plantronics CS50 Headset Motherboard Replacement: passo 5, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the microphone from the tip of the plastic.
    • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
  6. Plantronics CS50 Headset Motherboard Replacement: passo 6, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement: passo 6, imagem 2 %32
    • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
    • Use the plastic opening tool to separate the speaker casing from the headset face.
    • Add extra heat to the sides to melt the adhesive between the plastic connectors.
  7. Plantronics CS50 Headset Motherboard Replacement: passo 7, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement: passo 7, imagem 2 %32
    • Slowly separate the motherboard from the rest of the headset.
  8. Plantronics CS50 Headset Motherboard Replacement: passo 8, imagem 1 %32
    • Locate the microphone wires on the bottom of the motherboard.
    • Use a hairdryer or heat gun to melt the glue off of the motherboard.
  9. Plantronics CS50 Headset Motherboard Replacement: passo 9, imagem 1 %32
    • Flip the device over.
    • Use a soldering iron to remove the solder that holds the wires to the motherboard.
    • For help soldering, click here.
    • The microphone piece should be completely detached from the motherboard.
  10. Plantronics CS50 Headset Motherboard Replacement, Motherboard: passo 10, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement, Motherboard: passo 10, imagem 2 %32 Plantronics CS50 Headset Motherboard Replacement, Motherboard: passo 10, imagem 3 %32
    • Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
    • Using a plastic opening tool, prop open the edges.
    • Gently pull the black speaker casing up to remove it.
  11. Plantronics CS50 Headset Motherboard Replacement: passo 11, imagem 1 %32 Plantronics CS50 Headset Motherboard Replacement: passo 11, imagem 2 %32
    • Use the heat gun or blow dryer to melt the glue that connects the wires to the headset's motherboard.
    • The wires should come off as they are not soldered to the motherboard.
Conclusão
Joe
Membro desde: 04/12/12
117 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 17-29, Amido Spring 2012 Membro de Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 1,117
