Introdução
Use this guide to replace your headset's motherboard
O que você precisa
Flip the headset face down.
Squeeze both sides of the battery cover.
While squeezing, pull the cover up slowly to remove it.
Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
Apply additional heat at the tip of the microphone.
Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
Using a plastic opening tool, prop open the edges.
Gently pull the black speaker casing up to remove it.
