Introdução
The following steps will teach you how to disassemble your headset and install a new microphone.
O que você precisa
Flip the headset face down.
Squeeze both sides of the battery cover.
While squeezing, pull the cover up slowly to remove it.
Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
Apply additional heat at the tip of the microphone.
Conclusão
To reassemble your device, follow these instructions in reverse order. Replace the glue and solder where they are needed.
