Ir para o conteúdo principal
Plantronics CS50 Headset Battery Replacement
O que você precisa
  1. Plantronics CS50 Headset Battery Replacement, Battery: passo 1, imagem 1 %32 Plantronics CS50 Headset Battery Replacement, Battery: passo 1, imagem 2 %32 Plantronics CS50 Headset Battery Replacement, Battery: passo 1, imagem 3 %32
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
    Pergunte ao FixBot
    Comentar
  2. Plantronics CS50 Headset Battery Replacement: passo 2, imagem 1 %32 Plantronics CS50 Headset Battery Replacement: passo 2, imagem 2 %32 Plantronics CS50 Headset Battery Replacement: passo 2, imagem 3 %32
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order
Equipe
Cal Poly, Team 17-29, Amido Spring 2012 Membro de Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Membros
Autoria de 14 guias
2Comentários do guia
I created the article https://de.ifixit.com/Artikel/Battery_Pl... for a Silvercrest bluetooth transmitter, but I was not able to change the needed parts of this howto to link to that article.
anton2 - Responder Compartilhar
I replaced the battery with a new battery, I cleaned all the connectors and I reset the base and the headset is still not working
Lee kathryn lucas - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 48
Ao todo: 8,268
