Ir para o conteúdo principal
Photive Rain Motherboard Replacement
O que você precisa
  1. Photive Rain Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Motherboard Replacement, Battery: passo 3, imagem 1 %32 Photive Rain Motherboard Replacement, Battery: passo 3, imagem 2 %32
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
  4. Photive Rain Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
  5. Photive Rain Motherboard Replacement, Speaker: passo 5, imagem 1 %32
    • Carefully remove the front panel from the device.
  6. Photive Rain Motherboard Replacement: passo 6, imagem 1 %32
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  7. Photive Rain Motherboard Replacement: passo 7, imagem 1 %32 Photive Rain Motherboard Replacement: passo 7, imagem 2 %32
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
  8. Photive Rain Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • From the back of the motherboard, unscrew the three phillips head screws holding the motherboard in place.
  9. Photive Rain Motherboard Replacement: passo 9, imagem 1 %32
    • Pull the rubber away from the edge of the motherboard.
  10. Photive Rain Motherboard Replacement: passo 10, imagem 1 %32 Photive Rain Motherboard Replacement: passo 10, imagem 2 %32
    • Use the plastic opening tool to remove motherboard from device.
    • The second photograph displays a properly removed motherboard.
Conclusão
3 outras pessoas executaram este guia.
abcdef ghijk
Membro desde: 02/15/16
723 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2016 Membro de IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 309
