Ir para o conteúdo principal
Philips Sonicare FlexCare Battery Replacement
O que você precisa
  1. Philips Sonicare FlexCare Battery Replacement, Battery: passo 1, imagem 1 %32
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Battery Replacement: passo 2, imagem 1 %32
    • Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
    • Have a look to an alternative opening procedure.
  3. Philips Sonicare FlexCare Battery Replacement, Do not press on the shaft!: passo 3, imagem 1 %32
    • The previous version of this step told people to press on the shaft until the electronics were exposed. DO NOT DO THIS, it can snap locking tabs off
    • Using a small flathead screwdriver, release the two black locking tabs holding the internals in place
    • Slide the internals out of the toothbrush casing
    • Until this step is updated with new pictures, scroll down to step 5 to see the two tabs
  4. Philips Sonicare FlexCare Battery Replacement: passo 4, imagem 1 %32
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Battery Replacement: passo 5, imagem 1 %32
    • Remove the cap that is attached to the end of the interior by removing the two clasps that are holding it in place.
  6. Philips Sonicare FlexCare Battery Replacement: passo 6, imagem 1 %32
    • Desolder the battery from the circuit board. Here is a guide on how to desolder. Remove the old battery and replace it. Using the same guide, solder the battery in place.
    • The soldering points are shown in red.
Conclusão
42 outras pessoas executaram este guia.
Joanna Moraza
Membro desde: 04/14/15
1.886 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-6, Maness Spring 2015 Membro de Cal Poly, Team 4-6, Maness Spring 2015
CPSU-MANESS-S15S4G6
4 Membros
Autoria de 23 guias
37Comentários do guia
has anyone ever done this successfully? OMG it seems daunting!!!!
Jo - Responder
I'm going to try it. Now, to find a battery source.
Scott Minton - Responder
Anyone knows where to purchase such battery and its type/sort code?
Ben Salem - Responder
The battery is a 14500 li-ion with soldered pins.
I bought this one without pin and will try to solder them:
http://www.ebay.de/itm/371716530024
Here, you can buy the version with pins:
https://www.amazon.com/Battery-Sonicare-...
mamuc -
Prying open the bottom of the brush like that can damage the plastic. There's a damage-free technique detailed on this guide:
http://toothbrushbattery.com/guides/phil...
Dave W - Responder
Comentar
Visualizações:
Últimas 24 horas: 66
Últimos 7 dias: 472
Últimos 30 dias: 2,112
Ao todo: 343,217
