Ir para o conteúdo principal
Philips Sonicare DiamondClean Motor Replacement
O que você precisa
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: passo 1, imagem 1 %32 Philips Sonicare DiamondClean Motor Replacement, Motor: passo 1, imagem 2 %32
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: passo 2, imagem 1 %32
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Motor Replacement: passo 3, imagem 1 %32 Philips Sonicare DiamondClean Motor Replacement: passo 3, imagem 2 %32
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: passo 4, imagem 1 %32 Philips Sonicare DiamondClean Motor Replacement: passo 4, imagem 2 %32
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: passo 5, imagem 1 %32
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: passo 6, imagem 1 %32
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: passo 7, imagem 1 %32
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: passo 8, imagem 1 %32 Philips Sonicare DiamondClean Motor Replacement: passo 8, imagem 2 %32
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: passo 9, imagem 1 %32 Philips Sonicare DiamondClean Motor Replacement: passo 9, imagem 2 %32
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: passo 10, imagem 1 %32
    • Remove the motor and replace.
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
Do you have a part number for the motor?
Suraj Daryapurkar - Responder
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 39
Últimos 30 dias: 139
Duração total: 6,193
