Ir para o conteúdo principal
Philips Sonicare DiamondClean Circuit Board Replacement
O que você precisa
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32 Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: passo 1, imagem 2 %32
    • Pull the brush head from the toothbrush.
  2. Philips Sonicare DiamondClean Circuit Board Replacement: passo 2, imagem 1 %32
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Circuit Board Replacement: passo 3, imagem 1 %32 Philips Sonicare DiamondClean Circuit Board Replacement: passo 3, imagem 2 %32 Philips Sonicare DiamondClean Circuit Board Replacement: passo 3, imagem 3 %32
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Circuit Board Replacement: passo 4, imagem 1 %32
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Circuit Board Replacement: passo 5, imagem 1 %32
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
  6. Philips Sonicare DiamondClean Circuit Board Replacement: passo 6, imagem 1 %32
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 68
Duração total: 2,858
