Ir para o conteúdo principal
Philips Satinelle Motor Replacement
O que você precisa
    1. Philips Satinelle Motor Replacement, Plastic Cover: passo 1, imagem 1 %32 Philips Satinelle Motor Replacement, Plastic Cover: passo 1, imagem 2 %32 Philips Satinelle Motor Replacement, Plastic Cover: passo 1, imagem 3 %32
      • Remove the head by pushing it to the right.
      Pergunte ao FixBot
      Comentar
    2. Philips Satinelle Motor Replacement: passo 2, imagem 1 %32 Philips Satinelle Motor Replacement: passo 2, imagem 2 %32
      • Use a metal spudger to pry open the casing.
      • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
      Pergunte ao FixBot
      Comentar
    3. Philips Satinelle Motor Replacement: passo 3, imagem 1 %32
      • Pull the plastic casing apart with your hands.
      • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
      Pergunte ao FixBot
      Comentar
    1. Philips Satinelle Motor Replacement, Motor: passo 4, imagem 1 %32 Philips Satinelle Motor Replacement, Motor: passo 4, imagem 2 %32
      • Remove the components.
      Pergunte ao FixBot
      Comentar
    2. Philips Satinelle Motor Replacement: passo 5, imagem 1 %32 Philips Satinelle Motor Replacement: passo 5, imagem 2 %32 Philips Satinelle Motor Replacement: passo 5, imagem 3 %32
      • Hold the motor with the gears face away from you.
      • Gently push the motor out with your thumbs.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Marist, Team S1-G1, Chaterdon Fall 2018 Membro de Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Membros
Autoria de 8 guias
2Comentários do guia
i dont know what i am doing wrong but it is not openning
Aj Queen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 71
Ao todo: 2,953
