Introdução
This guide will teach how to disassemble Phillips Satinelle for parts replacement
O que você precisa
Unplug the device and remove the purple guard.
Remove the head by pressing the right side of the head (with the device facing away from you).
You will hear a 'click' and the head will become dislodged from the body of the device.
6 outras pessoas executaram este guia.
6 comentários
can we open the lower part which holds the motor and gear..
actualy the gear which holds the motor is gone bad i think.. so i want to replace it ..
can this be fixed..??
similar here, wanted to open the lower part where the cable goes in. the cable is broken at the entry.
To open main body …Click here
Thank you for this great tutorial. It really helps!
Can you please give us the dimensions for the gear’s teeth in step 7 and the corresponding gear in step 2 in the Philips Satinelle Motor Replacement tutorial? I can 3D print the gears, but I can’t find the dimensions online and the gears are simply to eroded to be able to measure them.
