Introdução
This guide will teach you how to replace the motor and will require some soldering.
O que você precisa
Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
Use the tweezers to pull out the inner power button.
4 outras pessoas executaram este guia.
4 comentários
¿Me puedes ayudar con algo?
Can you help me with something?
this guide was created also by nina lovekrist in 2015
Where can I get the motor with copper shaft?
