Ir para o conteúdo principal
Philips Norelco 5801XL Battery Replacement
O que você precisa
  1. Philips Norelco 5801XL Battery Replacement, Battery: passo 1, imagem 1 %32 Philips Norelco 5801XL Battery Replacement, Battery: passo 1, imagem 2 %32
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: passo 2, imagem 1 %32 Philips Norelco 5801XL Battery Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: passo 3, imagem 1 %32 Philips Norelco 5801XL Battery Replacement: passo 3, imagem 2 %32 Philips Norelco 5801XL Battery Replacement: passo 3, imagem 3 %32
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: passo 4, imagem 1 %32
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: passo 5, imagem 1 %32
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: passo 6, imagem 1 %32
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: passo 7, imagem 1 %32 Philips Norelco 5801XL Battery Replacement: passo 7, imagem 2 %32 Philips Norelco 5801XL Battery Replacement: passo 7, imagem 3 %32
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
Conclusão
3 outras pessoas executaram este guia.
Ben Gibbs
Membro desde: 02/16/16
361 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-2, Harley Spring 2016 Membro de IUPUI, Team 3-2, Harley Spring 2016
IUPUI-HARLEY-S16S3G2
Membros da 4
Autoria de 3 guias
2 comentários
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - Responder
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 53
Duração total: 4,023
