Ir para o conteúdo principal
Petcube Play 2 Camera Replacement
O que você precisa
  1. Petcube Play 2 Camera Replacement, Motherboard: passo 1, imagem 1 %32 Petcube Play 2 Camera Replacement, Motherboard: passo 1, imagem 2 %32 Petcube Play 2 Camera Replacement, Motherboard: passo 1, imagem 3 %32
    • Flip over the Petcube so the rubber bottom faces you.
    • Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
  2. Petcube Play 2 Camera Replacement: passo 2, imagem 1 %32 Petcube Play 2 Camera Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws under the rubber cover.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 Camera Replacement: passo 3, imagem 1 %32 Petcube Play 2 Camera Replacement: passo 3, imagem 2 %32
    • Use an opening pick or spudger to pry off the glass front panel.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 Camera Replacement: passo 4, imagem 1 %32 Petcube Play 2 Camera Replacement: passo 4, imagem 2 %32 Petcube Play 2 Camera Replacement: passo 4, imagem 3 %32
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 Camera Replacement: passo 5, imagem 1 %32 Petcube Play 2 Camera Replacement: passo 5, imagem 2 %32 Petcube Play 2 Camera Replacement: passo 5, imagem 3 %32
    • Once the internal assembly is removed, you should see a brass cylinder in the top left of the front face of the cube. At the top of that cylinder is a hole that leads down to a screw.
    • Remove it using a Phillips head size #1 screwdriver.
  6. Petcube Play 2 Camera Replacement: passo 6, imagem 1 %32 Petcube Play 2 Camera Replacement: passo 6, imagem 2 %32 Petcube Play 2 Camera Replacement: passo 6, imagem 3 %32
    • Flip the cube onto one of its sides to locate the pull tabs holding the two halves together.
    • Lift each of the five tabs using an opening tool to separate the two halves of the Petcube 2.
  7. Petcube Play 2 Camera Replacement: passo 7, imagem 1 %32 Petcube Play 2 Camera Replacement: passo 7, imagem 2 %32 Petcube Play 2 Camera Replacement: passo 7, imagem 3 %32
    • Disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 Camera Replacement: passo 8, imagem 1 %32 Petcube Play 2 Camera Replacement: passo 8, imagem 2 %32 Petcube Play 2 Camera Replacement: passo 8, imagem 3 %32
    • Use the size #1 Phillips screwdriver to remove the two 1 mm screws.
    • Carefully release the three tabs and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
  9. Petcube Play 2 Camera Replacement, Camera: passo 9, imagem 1 %32 Petcube Play 2 Camera Replacement, Camera: passo 9, imagem 2 %32
    • Use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • You can insert the arms of a pair of sharp tweezers into the cutouts and gently push the connector out of its socket.
    • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated.
  10. Petcube Play 2 Camera Replacement: passo 10, imagem 1 %32 Petcube Play 2 Camera Replacement: passo 10, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the three 1 mm screws securing the camera to the motherboard.
    • Remove the camera from the motherboard.
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
JoshBerm
Membro desde: 03/18/24
135 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-5, Konn Spring 2024 Membro de UMass Dartmouth, Team 1-5, Konn Spring 2024
UMASSD-KONN-S24S1G5
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 21
Últimos 30 dias: 21
Duração total: 81
