Ir para o conteúdo principal
Perfect Cooker RC301M Disassembly
O que você precisa
Documento em destaque
Pré-visualização da primeira página deste documento
Kitchen
Faça login para ver o documento completo
Login
    1. Perfect Cooker RC301M Disassembly, Perfect Cooker RC301M Disassembly: passo 1, imagem 1 %32 Perfect Cooker RC301M Disassembly, Perfect Cooker RC301M Disassembly: passo 1, imagem 2 %32
      • Remove the power cord and find a clean flat surface to work at.
      Pergunte ao FixBot
      Comentar
    2. Perfect Cooker RC301M Disassembly: passo 2, imagem 1 %32 Perfect Cooker RC301M Disassembly: passo 2, imagem 2 %32 Perfect Cooker RC301M Disassembly: passo 2, imagem 3 %32
      • Remove the lid by unhinging the side tabs.
      • Remove the inner pot and any other contents.
      Pergunte ao FixBot
      Comentar
    3. Perfect Cooker RC301M Disassembly: passo 3, imagem 1 %32 Perfect Cooker RC301M Disassembly: passo 3, imagem 2 %32 Perfect Cooker RC301M Disassembly: passo 3, imagem 3 %32
      • Flip the device over and look for the two screws recessed underneath the device.
      Pergunte ao FixBot
      Comentar
    4. Perfect Cooker RC301M Disassembly: passo 4, imagem 1 %32 Perfect Cooker RC301M Disassembly: passo 4, imagem 2 %32 Perfect Cooker RC301M Disassembly: passo 4, imagem 3 %32
      • Using a Phillips #2 screwdriver, remove the two 32.8 mm screws.
      Pergunte ao FixBot
      Comentar
    5. Perfect Cooker RC301M Disassembly: passo 5, imagem 1 %32
      • Carefully lift up the bottom to reveal the wires and mechanism.
      • Make sure not to pull it up too much as it is still connected to the device body with the center metal mechanism.
      Pergunte ao FixBot
      Comentar
    6. Perfect Cooker RC301M Disassembly: passo 6, imagem 1 %32
      • The center mechanism is directly in the center of the device and connects the switch to the middle
      • This part of the device raises and lowers the burner to change from the cook to warm function.
      • The two parts of the mechanism are connected by a simple metal “T-shaped” tab.
      Pergunte ao FixBot
      Comentar
    7. Perfect Cooker RC301M Disassembly: passo 7, imagem 1 %32 Perfect Cooker RC301M Disassembly: passo 7, imagem 2 %32 Perfect Cooker RC301M Disassembly: passo 7, imagem 3 %32
      • Disconnect the two metal arms.
      • It can be seen that the metal tab must be bent into a “U-shape” in order to fit through the other arm of the mechanism.
      • Take the small chain nose pliers and bend each side of the “T-shaped” tab inwards.
      • Use trial and error to bend the tabs until they are able to fit through the “U-shape” cut out in the other arm.
      Pergunte ao FixBot
      Comentar
    8. Perfect Cooker RC301M Disassembly: passo 8, imagem 1 %32 Perfect Cooker RC301M Disassembly: passo 8, imagem 2 %32
      • Separate the two parts of the devices.
      • The "U-shape" cut out can now be clearly seen.
      • The T-tab remains in the "U-shape" after slipping through the slot.
      Pergunte ao FixBot
      Comentar
Conclusão
Documentos anexados
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 33
Ao todo: 852
