Ir para o conteúdo principal
Pentax Super Program Shutter Timing Adjustment
  1. Pentax Super Program Shutter Timing Adjustment, Prepare the shutter: passo 1, imagem 1 %32 Pentax Super Program Shutter Timing Adjustment, Prepare the shutter: passo 1, imagem 2 %32
    • The shutter should be installed in the camera chassis.
    • Solder jumper wires to the red, brown and white shutter controls signals.
    • Solder a jumper wire to the positive battery terminal.
    • Solder a jumper wire to the ground connection.
    • Install the bottom cover and batteries.
    Pergunte ao FixBot
    Comentar
  2. Pentax Super Program Shutter Timing Adjustment, Prepare the front block: passo 2, imagem 1 %32 Pentax Super Program Shutter Timing Adjustment, Prepare the front block: passo 2, imagem 2 %32 Pentax Super Program Shutter Timing Adjustment, Prepare the front block: passo 2, imagem 3 %32
    • Solder the jumper wires from the shutter control wires.
    • Red wire connection.
    • White wire connection.
    • Brown wire connection.
    • Solder the jumper wire from positive battery.
    • Connect the ground wire to the camera chassis.
    • Connect the shutter release plate to the camera chassis (ground).
    Pergunte ao FixBot
    Comentar
  3. Pentax Super Program Shutter Timing Adjustment, Select the shutter speed: passo 3, imagem 1 %32 Pentax Super Program Shutter Timing Adjustment, Select the shutter speed: passo 3, imagem 2 %32
    • Turn the mode dial to the 'M' position.
    • Be careful not to let the ball bearing escape when passing through 'Auto' mode (the larger hole).
    • Adjust the shutter speed by grounding the contact posts for the shutter speed selector buttons.
    Pergunte ao FixBot
    Comentar
    • The camera has the necessary electrical connections to operate the shutter, but some of the mechanical actions have to be done manually.
    • Charge the mirror mechanism.
    • Charge the shutter.
    • Press the shutter release.
    • Push the opening curtain latch on the shutter.
    • Push the mirror return latch.
    Pergunte ao FixBot
    Comentar
  4. Pentax Super Program Shutter Timing Adjustment, Adjust curtain travel times: passo 5, imagem 1 %32
    • Measure curtain travel times with a shutter tester. If the shutter is far out of spec, it may be necessary to select a slower shutter speed to get a reading.
    • Adjust the lower gear for the opening curtain. Turn clockwise to decrease travel time and counter-clockwise to increase.
    • Adjust the upper gear for the closing curtain.
    • Both curtains should have a travel time of 5.6 ms over 22 mm. Incrementing the gears by one tooth changes the travel time by ~0.05 ms.
    Pergunte ao FixBot
    Comentar
  5. Pentax Super Program Shutter Timing Adjustment, Adjust curtain delay: passo 6, imagem 1 %32 Pentax Super Program Shutter Timing Adjustment, Adjust curtain delay: passo 6, imagem 2 %32
    • Set the shutter speed to 2000.
    • Adjust the eccentric post until the exposure time measures 0.5 ms.
    • The service manual gives an acceptable range of 0.45 to 0.6 ms for the 1/2000 setting. Other speeds should be accurate at this point.
    Pergunte ao FixBot
    Comentar
Conclusão
Sam Gustafson
Membro desde: 09/01/22
13.004 Reputação
Autoria de 78 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 40
Ao todo: 151
