Ir para o conteúdo principal
Pentax Super Program Mirror Box Mechanism Service
O que você precisa
    1. Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: passo 1, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: passo 1, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: passo 1, imagem 3 %32
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      Pergunte ao FixBot
      Comentar
    2. Pentax Super Program Mirror Box Mechanism Service, Remove mode dial: passo 2, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove mode dial: passo 2, imagem 2 %32
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      Pergunte ao FixBot
      Comentar
    3. Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: passo 3, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: passo 3, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: passo 3, imagem 3 %32
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      Pergunte ao FixBot
      Comentar
    4. Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: passo 4, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: passo 4, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: passo 4, imagem 3 %32
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      Pergunte ao FixBot
      Comentar
    5. Pentax Super Program Mirror Box Mechanism Service, Remove top cover: passo 5, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove top cover: passo 5, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Remove top cover: passo 5, imagem 3 %32
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      Pergunte ao FixBot
      Comentar
    1. Pentax Super Program Mirror Box Mechanism Service, Remove bottom cover: passo 6, imagem 1 %32
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      Pergunte ao FixBot
      Comentar
    1. Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: passo 7, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: passo 7, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: passo 7, imagem 3 %32
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      Pergunte ao FixBot
      Comentar
    2. Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB with adjustment pots: passo 8, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB with adjustment pots: passo 8, imagem 2 %32
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      Pergunte ao FixBot
      Comentar
    3. Pentax Super Program Mirror Box Mechanism Service, Unsolder motor drive connections: passo 9, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Unsolder motor drive connections: passo 9, imagem 2 %32
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      Pergunte ao FixBot
      Comentar
    4. Pentax Super Program Mirror Box Mechanism Service, Remove tripod mount: passo 10, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove tripod mount: passo 10, imagem 2 %32
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      Pergunte ao FixBot
      Comentar
    5. Pentax Super Program Mirror Box Mechanism Service, Detach ISO resistor assembly: passo 11, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Detach ISO resistor assembly: passo 11, imagem 2 %32
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      Pergunte ao FixBot
      Comentar
    6. Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: passo 12, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: passo 12, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: passo 12, imagem 3 %32
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      Pergunte ao FixBot
      Comentar
    7. Pentax Super Program Mirror Box Mechanism Service, Unsolder flash sync wires: passo 13, imagem 1 %32
      • Unsolder two gray wires.
      Pergunte ao FixBot
      Comentar
    8. Pentax Super Program Mirror Box Mechanism Service, Unsolder shutter wires: passo 14, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Unsolder shutter wires: passo 14, imagem 2 %32
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      Pergunte ao FixBot
      Comentar
    9. Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: passo 15, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: passo 15, imagem 2 %32
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      Pergunte ao FixBot
      Comentar
    10. Pentax Super Program Mirror Box Mechanism Service, Unscrew front board: passo 16, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Unscrew front board: passo 16, imagem 2 %32
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      Pergunte ao FixBot
      Comentar
    11. Pentax Super Program Mirror Box Mechanism Service, Remove mirror box and front board: passo 17, imagem 1 %32
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      Pergunte ao FixBot
      Comentar
    12. Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Front Block: passo 18, imagem 1 %32
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      Pergunte ao FixBot
      Comentar
    1. Pentax Super Program Mirror Box Mechanism Service, Unsolder Main PCB: passo 19, imagem 1 %32
      • Unsolder one orange and one blue wire for the mirror release solenoid.
      • Unsolder one pink wire for the LCD backlight.
      • Unsolder two purple wires for the TL switch.
      • Unsolder one green wire for the MD switch.
      Pergunte ao FixBot
      Comentar
    2. Pentax Super Program Mirror Box Mechanism Service, Unsolder lens mount connections (early production): passo 20, imagem 1 %32
      • Unsolder six wires for the lens mount pin connections.
      • These are only present on the early production models. Later production models moved these connection points to the flex connector.
      Pergunte ao FixBot
      Comentar
    3. Pentax Super Program Mirror Box Mechanism Service, Unsolder aperture resistor: passo 21, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Unsolder aperture resistor: passo 21, imagem 2 %32
      • Unsolder two yellow wires for the aperture resistor.
      Pergunte ao FixBot
      Comentar
    4. Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: passo 22, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: passo 22, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: passo 22, imagem 3 %32
      • Unsolder the red and black wires for the metering cells in the eye piece.
      • Unsolder pink and green wires for the flash sync connections.
      Pergunte ao FixBot
      Comentar
    5. Pentax Super Program Mirror Box Mechanism Service, Unsolder front board connections (early production): passo 23, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Unsolder front board connections (early production): passo 23, imagem 2 %32
      • Unsolder blue and black wires for self-timer LED.
      • Unsolder orange wire for beeper.
      • Unsolder gray and pink wires for aperture solenoid.
      • Unsolder light blue and yellow wires for aperture optical encoder.
      • Unsolder purple wire for self-timer contact.
      • Remove one screw.
      Pergunte ao FixBot
      Comentar
    6. Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB connection (late production): passo 24, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB connection (late production): passo 24, imagem 2 %32
      • Remove two M1.4 x 2 mm screws.
      • Use a spudger to gently pry off the connector plate.
      • Remove the silicone insulating pad.
      Pergunte ao FixBot
      Comentar
    7. Pentax Super Program Mirror Box Mechanism Service, Detach viewfinder LCD: passo 25, imagem 1 %32
      • Remove two M1.4 x 1.6 mm screws.
      • Look for shim washers when removing and note their position.
      Pergunte ao FixBot
      Comentar
    8. Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: passo 26, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: passo 26, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: passo 26, imagem 3 %32
      • Loosen one M1.7 x 4.5 mm screw but leave it in place.
      • Remove two M1.7 x 1.6 mm screws.
      • Remove the mirror governor.
      • Remove one plastic bushing.
      Pergunte ao FixBot
      Comentar
    9. Pentax Super Program Mirror Box Mechanism Service, Remove main PCB: passo 27, imagem 1 %32
      • Gently lift away the PCB from the mirror box.
      • The TTL flash metering cell needs to be unseated from the side of the mirror box to free the PCB for removal.
      Pergunte ao FixBot
      Comentar
    1. Pentax Super Program Mirror Box Mechanism Service, Detach front flex PCB: passo 28, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Detach front flex PCB: passo 28, imagem 2 %32
      • Lift flex PCB off of mounting posts.
      • Remove silicone insulator pad.
      Pergunte ao FixBot
      Comentar
    2. Pentax Super Program Mirror Box Mechanism Service, Remove beeper: passo 29, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove beeper: passo 29, imagem 2 %32
      • Remove one screw and retainer plate.
      • Remove beeper.
      Pergunte ao FixBot
      Comentar
    3. Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: passo 30, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: passo 30, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: passo 30, imagem 3 %32
      • Remove two M2 x 3 mm screws.
      • Remove one M1.7 x 3 mm screw.
      • Charge and release the mirror so it is in the taking position (up against the focusing screen).
      Pergunte ao FixBot
      Comentar
    4. Pentax Super Program Mirror Box Mechanism Service, Remove mirror box: passo 31, imagem 1 %32
      • Lift mirror box away from front lens board.
      Pergunte ao FixBot
      Comentar
    5. Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Mirror Box: passo 32, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Mirror Box: passo 32, imagem 2 %32
      • Check the following coupling points between the front lens board and the mirror box.
      • Aperture control.
      • Self-timer lever is above the mirror release latch.
      • Depth of field preview lever.
      Pergunte ao FixBot
      Comentar
      • Insert wisdom here.
      Pergunte ao FixBot
      Comentar
    1. Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: passo 34, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: passo 34, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: passo 34, imagem 3 %32
      • Remove one M1.3 x 2.1 mm shoulder screw.
      • Remove one M1.3 x 2.4 mm screw.
      • Remove coil spring.
      • Note the rubber bumper on the pivot post. This should be removed and cleaned before reassembly.
      Pergunte ao FixBot
      Comentar
    2. Pentax Super Program Mirror Box Mechanism Service, Remove shutter release lever: passo 35, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove shutter release lever: passo 35, imagem 2 %32
      • Remove one M1.5 x 3.5 mm screw.
      • Remove the bias spring.
      • Remove the brass bushing.
      Pergunte ao FixBot
      Comentar
    3. Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: passo 36, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: passo 36, imagem 2 %32 Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: passo 36, imagem 3 %32
      • Unhook and remove the coil spring. It may be tacked in place with lacquer.
      • Remove one M1.3 x 4.5 mm screw.
      • Remove the depth of field preview lever.
      • Remove the bushing.
      Pergunte ao FixBot
      Comentar
    4. Pentax Super Program Mirror Box Mechanism Service, Remove auto-aperture control lever: passo 37, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove auto-aperture control lever: passo 37, imagem 2 %32
      • Use a spanner wrench or u-bit to remove two nuts.
      • Lift off auto-aperture control lever.
      Pergunte ao FixBot
      Comentar
    5. Pentax Super Program Mirror Box Mechanism Service, Remove mirror flip-up lever: passo 38, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove mirror flip-up lever: passo 38, imagem 2 %32
      • Lift off mirror flip-up lever.
      • Remove shim washer.
      • Remove plastic bushing.
      Pergunte ao FixBot
      Comentar
    6. Pentax Super Program Mirror Box Mechanism Service, Remove aperture stop-down lever: passo 39, imagem 1 %32 Pentax Super Program Mirror Box Mechanism Service, Remove aperture stop-down lever: passo 39, imagem 2 %32
      • Remove aperture stop-down lever.
      • Installation Notes: Ensure the lever foot is placed properly between the mirror flip-up spring and the mirror return lever during reassembly.
      Pergunte ao FixBot
      Comentar
    7. Pentax Super Program Mirror Box Mechanism Service, Clean mirror box components: passo 40, imagem 1 %32
      • Remove two old rubber bumpers.
      • Clean all pivots with isopropyl alcohol.
      • Clean all removed components with isopropyl alcohol.
      Pergunte ao FixBot
      Comentar
    8. Pentax Super Program Mirror Box Mechanism Service, Reassembly Notes: passo 41, imagem 1 %32
      • The mirror mechanism does not need lubrication to operate properly. Most moving interfaces run dry.
      • High friction latching points can be lubricated with a heavy moly grease to reduce wear.
      • Replacement rubber dampers are optional. Silicone tubing cut to length is good source.
      Pergunte ao FixBot
      Comentar
Conclusão
Sam Gustafson
Membro desde: 09/01/22
14.444 Reputação
Autoria de 78 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 50
Ao todo: 540
