Ir para o conteúdo principal
Pentax PZ-10 Back Cover Locking Switch Spring Replacement
O que você precisa
  1. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Bottom Cover: passo 1, imagem 1 %32
    • With the lens face up and the bottom panel of the camera facing you, remove the two 7mm screws on the left using the J0 screwdriver.
    • Remove the six 4.3mm screws in the middle and right of the panel using the J0 screwdriver.
    • Pull off the bottom casing to remove.
    Pergunte ao FixBot
    Comentar
  2. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing Bottom Casing: passo 2, imagem 1 %32
    • With the screws removed, the bottom casing should come off very easily by pulling on the casing.
    Pergunte ao FixBot
    Comentar
  3. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Back Cover: passo 3, imagem 1 %32
    • Place the camera on its side so the lens is facing left.
    • Press down on the locking switch on the side panel facing you.
    Pergunte ao FixBot
    Comentar
  4. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: passo 4, imagem 1 %32
    • With the door unlocked, rotate the device to access the bottom.
    Pergunte ao FixBot
    Comentar
  5. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, gently remove the metal tab securing the back door axle.
    • The door will come loose at this point, watch for any loose parts that may also come out.
    Pergunte ao FixBot
    Comentar
  6. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Side Panel: passo 6, imagem 1 %32
    • Once the back cover is fully removed, remove the two 4.35mm screws attaching the cover of the unlocking switch, and remove the plate.
    Pergunte ao FixBot
    Comentar
  7. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Spring: passo 7, imagem 1 %32
    • Locate the spring at the upper left corner of the face, and pull the rings of the spring off of the pins to remove it using plastic opening tools.
    • You are now ready to replace the spring.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Su
Membro desde: 04/20/15
107 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 729
