Introdução
Use this guide to replace the LCD viewing screen on the back of the Pentax Optio WG-2.
O que você precisa
Passo 1 Back Case
Cuidado: os passos de 1 a 6 são provenientes de um guia marcado como em andamento.
Remove all four 1 mm JIS #00 screws from the back of the camera.
Ferramenta utilizada neste passo:Tweezers$4.99
Carefully remove the clear tape covering the screws and the ribbon cable.
We want to remove the larger silver panel (right). The best way to do this is to slightly bend the cover backwards and use the tweezers to grab a corner and slowly lift the screen up and out.
2Comentários do guia
Dónde puedo comprar el Display?
Where I can buy the dispaly?
