Introdução
Use this guide to remove and replace a damaged battery cover on the Pentax Optio WG-2.
O que você precisa
Lift the cover as you normally would if replacing battery.
Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
Quase terminado!
Conclusão
