Ir para o conteúdo principal
Pentax Optio WG-2 Battery Compartment Door Replacement
O que você precisa
  1. Cuidado: as etapas de 1 a 6 são provenientes de um guia marcado como em andamento.
    Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: passo 1, imagem 1 %32 Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: passo 1, imagem 2 %32
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 Battery Compartment Door Replacement: passo 2, imagem 1 %32
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 Battery Compartment Door Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 Battery Compartment Door Replacement: passo 4, imagem 1 %32 Pentax Optio WG-2 Battery Compartment Door Replacement: passo 4, imagem 2 %32 Pentax Optio WG-2 Battery Compartment Door Replacement: passo 4, imagem 3 %32
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 Battery Compartment Door Replacement: passo 5, imagem 1 %32
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 Battery Compartment Door Replacement: passo 6, imagem 1 %32
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: passo 7, imagem 1 %32 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: passo 7, imagem 2 %32 Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: passo 7, imagem 3 %32
    • Lift the cover as you normally would if replacing battery.
    • Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
    • There is a pin (3/4 of an inch long) that attaches the cover to the camera and it will come loose when the cover is removed.
Conclusão
Matthew Bessette
Membro desde: 03/04/16
658 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 6-7, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G7
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 793
