Introdução
Removing the bottom cover will give you access to the slow speed governor and allow you to inspect parts of the winding mechanism in the camera. Further disassembly is usually required to make a repair.
O que você precisa
Remove three M1.7 x 2.0 mm countersunk screws.
Lift off bottom cover.
Remove loose plastic housing for motor drive contacts.
