Ir para o conteúdo principal
Pebble Time Circuit Board Replacement
O que você precisa
  1. Pebble Time Circuit Board Replacement, Screen Cover: passo 1, imagem 1 %32
    • Lay the watch flat on your workstation.
  2. Pebble Time Circuit Board Replacement: passo 2, imagem 1 %32 Pebble Time Circuit Board Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Circuit Board Replacement: passo 3, imagem 1 %32
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Circuit Board Replacement: passo 4, imagem 1 %32
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Circuit Board Replacement, Screen: passo 5, imagem 1 %32
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Circuit Board Replacement: passo 6, imagem 1 %32
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Circuit Board Replacement: passo 7, imagem 1 %32 Pebble Time Circuit Board Replacement: passo 7, imagem 2 %32 Pebble Time Circuit Board Replacement: passo 7, imagem 3 %32
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Circuit Board Replacement, Circuit Board: passo 8, imagem 1 %32
    • Keep the watch flat on your workstation.
  9. Pebble Time Circuit Board Replacement: passo 9, imagem 1 %32
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Circuit Board Replacement: passo 10, imagem 1 %32 Pebble Time Circuit Board Replacement: passo 10, imagem 2 %32 Pebble Time Circuit Board Replacement: passo 10, imagem 3 %32
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Circuit Board Replacement: passo 11, imagem 1 %32
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Circuit Board Replacement: passo 12, imagem 1 %32 Pebble Time Circuit Board Replacement: passo 12, imagem 2 %32
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
Conclusão
Nicolas Hempe
Membro desde: 02/15/17
1.468 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Spring 2017 Membro de USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,008
